DJBlade
Hi, i've just bought a Bryston 4B SST to power my OB1's, what 3 channel power amps are out there for the other channels ? Can you recommend anything, the obvious choice is the 6B SST, but a, just cant afford a new one, and b, they dont appear much on the used market, i dont want to continue using my Arcam P7 (but will for the time being)
Thanks in advance for any advice/suggestions.
