Bryston 3B power amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by FookLai, Apr 24, 2002.
  1. FookLai
    FookLai
    I know Bryston 3B got many version like NRB THX and the lastest ST series. May I know is there a different between them in term of sound quality? Did anyone compare before for both amp? I am a owner of Bryston 3B NRB-THX. I am thinking is it necessary for me to upgrade it to the ST series. Thanks for all your input.
    Fook Lai
  2. Lowrider
    Lowrider
    I did read that the ST is much better than the NRB, THX just means it has triggers...
  3. FookLai
    FookLai
    thanks for your comment..... looks like my pocket will burn a hole again.... :(
  4. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    Brystons are not cheap. You'll need to budget approx £800 per 250W channel. I recently sold my 5B-ST (3x120B) that was 2yr old for £1300.
  5. FookLai
    FookLai
    can let us know why are you selling the 5B ST? No good?
  6. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I have moved all my equipment 1 floor up into a separate cabinet that become too small and too hot to house 2nd bryston that I needed for my 5.1 setup.
    I decided to sell Bryston amp and Yamaha DSP-A1 decoder and replace them with Denon A1SR (subject to overcoming ventilation problems).
    Quality wise Bryston (and Krell 250) were the best amps I had. If space and heat are not a problem in your setup, money being no constraint, there is very little else to stop you buying.
    Best prices for Brystons are from shop selling equipment for professional musicians. 3B-ST new goes for approx £1,600.
