Brush/ cable entry faceplate
Discussion in 'Home Cinema Building DIY' started by adamCCC, Sep 19, 2016.
Tags:
  1. adamCCC
    adamCCC
    Aug 27, 2009
    305
    +12
    Hello
    I am putting a cable entry/ brush faceplate in the living room to hide wires behind the wall going from tv to set top boxes etc, something like this:
    [​IMG]
    What do people normally use in terms of a back box or trunking? Is there a specific back box used that has the top section open or do you just use a normal back back and cut the top part off yourself?
    I also cant find any trunking or conduit to match the size of a double gang back box.
    Any help would be much appreciated.
    Adam
  2. PsyVision
    PsyVision
    Dec 6, 2008
    2,020
    116
    Bath
    +1,817
    When I did this I used some big square trunking and then used a dremel to cut the back box to match. I then applied some rubber around the edge of the cut back box to prevent cables being cut when moving about.
  3. adamCCC
    adamCCC
    Aug 27, 2009
    305
    +12
    Good idea softening the edges!
    Do you know what size the trunking was or where you got it? Can't seem to find anything that matches the size of a double gang backplate
  4. PsyVision
    PsyVision
    Dec 6, 2008
    2,020
    116
    Bath
    +1,817
