Browser freezes, then i need to restart vista.
Discussion in 'Microsoft Windows' started by clarksonwayne, Feb 6, 2009.
  1. clarksonwayne
    clarksonwayne
    Dec 11, 2008
    A few months ago for no reason i can tell apart from vista being vista, my browser started to freeze so i'd close it down and open another and the new window would just sit there as if it was loading but never get anywhere.
    First i checked my internet that was still working fine computer was still connected, email client and msn were working. So i restart the computer and everthings ok, some times for a hour, sometimes for 5 minutes then it happens again.
    So i clear the cach, cookies and reset IE to default, no change. I have tried firefox and many other browsers and i get the same.
    I really don't want to do a system restore, it took me a month putting all my albums back on it last time.
    Any ideas?
    Thanks, Wayne.
  2. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Move all your albums onto a separate partition or drive.
    Then restores/re-installs will be less painful.
  3. clarksonwayne
    clarksonwayne
    Dec 11, 2008
    I think i've sorted it, i believe it was my anti-v after all. Very odd behaviour by it.
    Thanks anyway.
  4. Figment
    Figment
    Apr 2, 2005
    811
    Berkshire
    +39
    Did you really solve this problem ? I have had the same for weeks now on my new desktop as has my daughter on her laptop. I have been unable to find a solution. Its driving me crazy, once it stops loading pages I can't even shut the pc down normally and have to power off from the start button on the front of the pc.
  5. sunnybacon
    sunnybacon
    Mar 6, 2008
    3,267
    Leicester
    +433
    Used to happen to me, and all of a sudden it just stopped. I have absolutely no clue why :confused:
  6. BAZIL71
    BAZIL71
    Aug 16, 2009
    Hullo guys,
    Could you find a solution? It happens to me, while using IE, Chrome, Firefox and Safari (yep, I tried all :))
    Best regards,
    BAZIL71
  7. aliEnRIK
    aliEnRIK
    May 21, 2006
    819
    Preston
    +71
    Download MALWAREBYTES (Make sure you click 'DOWNLOAD LATEST VERSION')
    Download Malwarebytes Anti-Malware 1.40 - FileHippo.com
    UPDATE and FULL SCAN
    Post the log here AFTER youve deleted everything it finds
    reboot
    Download HIJACK THIS (Make sure you click 'DOWNLOAD LATEST VERSION')
    Download HijackThis 2.0.2 - FileHippo.com
    Click DO A SCAN AND SAVE A LOGFILE (Takes seconds) then post the log so we can see whats running
    (do NOT do anything else with Hijack but scan and post the FULL log)
  8. workaholic1223
    workaholic1223
    Dec 13, 2009
    2
    You probably have McAfee Security Suite and Vista operating system. I recommend you turn off McAfee SiteAdvisor located in add on section of internet browser you are using. You must restart browser for change to take effect.
  9. workaholic1223
    workaholic1223
    Dec 13, 2009
    2
  10. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    This problem sounds like the Linkscanner one associated with AVG!
