Broken Wiimote!!! NO - NOT ON XMAS EVE!!
Discussion in 'Nintendo Wii-U & 3DS' started by Dave1979, Dec 25, 2006.
  1. Dave1979
    Dave1979
    Jun 14, 2006
    464
    +17
    Playing rayman and my wiimote (the one that came with the wii) has stopped working!!! It is fine on with pointing and clicking but on the games where you have to shake the wiimote like the music games and the running games shaking the wiimote has no effect!! I assume the accelerometor (sic) has broken!?!?!? BAWS!! Hopefully Gamestation will do a straight swap for a new wiimote on Boxing Day
  2. DeanTheDon
    DeanTheDon
    May 17, 2006
    697
    Cambridge
    +45
    Unlucky mate. Glad I've got 2 incase one screws up!
  3. CFCCFC
    CFCCFC
    Sep 24, 2006
    183
    +16
    Yeah me too...and on Rayman...kind of wondering if the Wiimote can stand up to it. Pity I bought mine from Currys online - rather than wrestle with them I'm going to get in touch with Nintendo for a replacement.
    Luckily I had the spare - but now I'm neurotic in case that one dies too. No more Rayman for me at the moment!
  4. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    No need, you can take back faulty goods to your local Curry's store. It would be quicker and easier to go down to your local one on boxing day and explain the situation and ask for a replacement Wii-mote. When we got our HDTV the remote didn't work, we just went in and told them and they gave us a spare remote and quite obviously they don't just have those lying around it was either from the store's TV that they have set up or it was from another brand new boxed TV. So they should replace the wii-mote with a separate one no problems. Or if you don't want to try that you could go to Curry's or infact pretty much any electronics/games shop on boxing day buy a new Wii-mote swap it for your broken one and tell them it was broken when you got it and ask for a refund.
  5. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    The problem may not be whether the store can pull strings for you but actually do they have any stock to help. A lot of Currys stores are still struggling for stock at the moment.
  6. makey
    makey
    Mar 11, 2004
    198
    28
    +26
    same here remote sensor not working all buttons work and can move hand about screen but when trying to swing or throw nothing other one works fine
    gutted aswell
  7. Andyduz
    Andyduz
    Nov 5, 2006
    81
    Wigan
    +22
    Hi, same thing just happened to me with Rayman and I managed to screw up 2 controllers!! Luckily, unplugged console from wall socket, plugged it back in, synced controls and they both work again. Give this a try if you haven't already. Not sure whether to try Rayman again.
  8. Dave1979
    Dave1979
    Jun 14, 2006
    464
    +17
    It was the Rayman running game - I was shaking the wiimote and the nunchuk up and down like a madman. Though they would have stress tested them to account for this kind of play. Re-synching it does not work for me!!
  9. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    bugger, i was tempted with rayman but this has put me off slightly:mad:
  10. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    My remotes work fine after a morning on rayman. Go for it dapax.
  11. simms
    simms
    Jun 30, 2005
    19
    I've heard that giving your remote a slight knock can make help unstick the accelerometor. I'm not saying you should knock it against a solid object but try knocking against your leg or something. Maybe worth a try.
  12. makey
    makey
    Mar 11, 2004
    198
    28
    +26
    i gave mine a bang against my leg now its working fine
    thanks simms for advice
    was about to trail kids out to shops tomorrow for replacement
    only downside its now not today will have to wait till tomorrow for some 2 player action
  13. IanW1977
    IanW1977
    Dec 30, 2002
    4,580
    West Midlands
    +484
    Our Wii Nunchuck broke on Thursday night - No replacements availble till next year now:mad:
  14. CFCCFC
    CFCCFC
    Sep 24, 2006
    183
    +16
    thanks for the tips guys - I think we'll give a try to switching off and resynching, give it a bang, if that doesn't work I'll give Currys a call and see if they actually have any in stock.
    And if not I might try the evil plan of buying one (if I can find one) then replacing it for a refund :)
  15. Andyduz
    Andyduz
    Nov 5, 2006
    81
    Wigan
    +22
    Dapex, just tried Rayman again and it works fine now. Give it a go.
  16. little eagle
    little eagle
    I had same problem - wiimote moves cursor, buttons are working but i cant swing in a game. Reseted unit, baneg controller in my leg - everything ok. I think that it is not about reseting becouse i did that before.
    THanks again.
    gretings, Nenad
  17. littlesheepy
    littlesheepy
    Apr 18, 2006
    5,706
    Staffs
    +605
    Have you tried changing your Wii to running at 60hz for Rayman. I was having the same problem (the hitting the radios game drove me nuts!) and apparently with Rayman, even tho it says on the box 50/60, it needs to be set at 60 for the running/shaking games to work. Mine worked like a dream when i changed it! Worth a go if you haven't :smashin:
  18. shed
    shed
    Feb 14, 2007
    118
    London, UK
    +14
    Yeah, same for me. I couldn't complete the radios game for love nor money until I changed it to 60Hz. So if it's only Rayman that it stops working on, it could well be the game and not the wiimote that's faulty.
