Broken speakers ? Help !
Discussion in 'Hi-Fi Stereo Systems & Separates' started by azs, Aug 23, 2005.
  1. azs
    azs
    Can anyone help...
    just connected my new pre-amp and made the mistake of leaving the input selector on phono. When I powered up, dispite the volume being on zero I got loads of feedback and interference through the speakers.
    I powered down, selected CD,powered back and everything is OK...apart from a total loss of high freqency drive.
    I've tested another pair of speakers and it's definitely either the internals or the tweeters...... any idea on a fix or (fat chance) a reset mechanism ??????
    Mission 775s
    Appreciate any help....
  2. la gran siete
    la gran siete
    Oct 5, 2003
    24,771
    Deep in the bowels of sussex where the angloargies
    +1,766
    cant see why leaving it on mono should,ve caused all that feedback :confused:You should get no sound at all if your trying to play CDs . Maybe someone else could help more but it sounds to me like you might have blown the tweeters but I'm not technical. BTW you'd be better off taking your post to the speakers section
