Broken Speaker!
Discussion in 'Home Cinema Speakers' started by dinoprada2003, Oct 9, 2004.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,429
    2
    LONDON
    +5,133
    Damm it!!! I manged to knock down my Acoustic energy R/L last night and the front has broken off,Exposing the inards of the speaker.What would be the best glue to "stick it back together?"
    Thank's
    D.
  2. andrew1810
    andrew1810
    Apr 4, 2004
    1,047
    North East
    +54
    Standard wood glue will do the trick, I had to repair some Kef's which had been dropped and the woodglue is holding the fronts on fine now
    Check the speakers aren't damaged and haven't come unplugged first though to save having to take them apart again later
    Andrew
  3. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,429
    2
    LONDON
    +5,133
    There not wood though mate,Would it still work though?they are a form of hard plastic.
  4. andrew1810
    andrew1810
    Apr 4, 2004
    1,047
    North East
    +54
    Is it a plastic front with a wooden/mdf cabinet? If they are, the wood glue will hold these two together.
    Otherwise I would think any strong glue would do the same, I used some araldite for repairing speaker cones and I think this will stick anything to anything!!
  5. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,429
    2
    LONDON
    +5,133
    Thank's i'll give the araldite a go :thumbsup:
