Broken Sony
Discussion in 'Blu-ray & DVD Players & Recorders' started by Brox, Sep 2, 2004.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Don't have the details yet but my friend has a sony DVD player that is 18 months old and now seems to scratch disks - it was bought from Curry's, what is the chance they will do something about it?
  2. WYNIR0
    WYNIR0
    Jul 16, 2004
    190
    London
    +12
    Zero chance I'd say, what with it being 18 mnths old. Scratching Discs how exactly?, sure it's not just down to a mucky lense making it jump?.
    My ex wife gave me our 'broken' panasonic player which she said was jumping when playing discs, saying if I fixed it I could have it. I ran the lense cleaner through it once and it's never jumped since.
    :devil:
  3. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Will try and get more information - but thought that whe you buy something it should last as long as someone should reasonably expect it to? and for a DVD player it should be a lot longer.
  4. WYNIR0
    WYNIR0
    Jul 16, 2004
    190
    London
    +12
    My understanding was that an item should be 'fit for it's intended purpose' but once you're outside the manufacturers guarentee then you're on your own.
  5. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Its possible that the disc is not being spun properly and it is hitting off the actual tray. You might hear a slight scraping sound when its spinning.
