Broken Sony Receiver, Help!!
Discussion in 'AV Receivers & Amplifiers' started by bunbenho, Apr 5, 2002.
Tags:
  1. bunbenho
    bunbenho
    Hi all,
    I was moving to my new home, and when i try to pack my Sony 1070 receiver, i foolishly broke the Master Volumne Button. Damn! I live in London and is there anyone can direct me to some where to get it fixed!
    i went back to Sony Store, they said it will take around 4-5 weeks and charge £50. (It is a bit too much just for a button, isn't it?)
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Wat is actually broke ?
    The Knob itself or the shaft that holds it on?
    If the shaft im sure you would be able to get a replacement part from maplins.
    Allthough 50 quid seems expensive its gonna cost that for anyone to open it up and fix it.
    Unless your prepared to do it yourself?
