Broken on/off switch Pioneer CD player
Jambutty1
Hi, if anyone can help: I have an old (but trusty) Pioneer separates system, which still functions well - apart from the tape player (which expired due to over-use - ah, the days before children!) and the CD player, which started turning itself off, then back on, sporadically - except that now it is off altogether, and refuses to come back on. While it was just playing up I opened it up to see if it was just a loose wire, but it definitely seemed to be the on/off switch, because waggling it triggered something to turn it back on (but not off, strangely). It is a push-button switch, sitting on a circuit board, but the switch itself seems to be 1 piece, or I'd have had it apart already... Is there a generic switch I can replace it with, or does each manufacturer have idiosyncracies design to make it harder to do so? I don't want to take it the local repairer, pay the £50 deposit, and have him put it in a cupboard before telling me he can't repair it. Any thoughts?
Jambutty1
bow79
is there an auxiliary input on this system probably 2 phonos at the back. plug an alternative CD player into it.
RBZ5416
Post a close-up pic of the switch together with any markings on it. There's a reasonable chance it can be replaced.
Jambutty1
thanks guys, here are 2 pics of the switch. I took it apart to see if I could clean it up/re-tool it, and got it working again... but then it cut out. On the picture of the copper rocker, the little blob on the end is a dab of solder I put on the contact, in case there was a gap - there was a small amount of blacking on the contact, but it was not pitted or anything to suggest arcing. It doesn't work at all now...
RBZ5416
Can't read the marking printed/stamped on it but Googling them should give some results. Can't help further without seeing the pin locations of where it mounts on the PCB.
Edit
is it like this?
Jambutty1
Unfortunately the darned thing is soldered on; if it was on pins I'd have been fairly confident about replacing it. Is this more legible?
RBZ5416
Not getting anything from those markings. The PCB is going to have to come out (as it will anyway to replace the switch). If it is as I pictured then you can have that one if you PM your address, just need to find someone to fit it.
You could also try Googling for a service manual with a parts list.
Jambutty1
Crocodile, I did PM you, did you get it? I have had no joy trying to locate a switch that looks remotely like the one that doesn't work, any help gratefully received.
