broken laptop :(
Discussion in 'Desktop & Laptop Computers Forum' started by SillySausage, Aug 2, 2005.
  1. SillySausage
    SillySausage
    Jul 10, 2004
    596
    Leicester
    +14
    Possibly a little OT, but I am not sure where to post this.
    Well, silly me took my OH's Sony Vaio V505 to bits to inspect a faulty cd/dvd rom.
    I got it to virtual component parts, looked at the rom and found out that I could have removed it in three screws instead of 403
    So it was put back together and now the feckin thing don't work at all...
    All I get it a flashing power and battery light when holding accross the power button - no boot at all, or even sign of life.
    I've rechecked everything twice and it seems to be built back properly, but doesn't work.
    Wouldn't care, but only yesterday I took my own laptop apart and sorted that no problem.... grrr.
    Adam.
  2. The Dude
    The Dude
    May 21, 2004
    6,349
    Beverley, East Yorkshire
    +2,713
    is the installed RAM built onto the board or on a plug in module underneath?
    A poorly seated RAM module would give you exactly this type of thing, not uncommon at all after taking a laptop chassis apart...
    well worth a check at least.... you might get lucky. ;)
  3. Maff et1
    Maff et1
    The ribbon cables can also sometimes move as you reassemble
