Quantcast
broken HDMI cable. help!
Starless
hey,
i have an HDMI cable that is buried in the wall and secured there with insulating foam so replacing the entire cable is not an option. the tip on one end just came right off so i'm looking for a solution. does anyone know where i can get an HDMI wall plate that i can solder the cable to?
thanks!
pwood
HDMI cables connectors are rather complex and if you get wrong the results could cause issue with your tv. Best person to ask is Mark Grant cables as he custom builds HDMI cables
