Broken Audio jack on NW-HD5
Discussion in 'Headphones, Earphones & Portable Music' started by redherring, Nov 3, 2005.
  1. redherring
    redherring
    Hi guys!
    I own a black Sony Nw-Hd5, which I have had for a couple of months now, no problems. But the other day, I powered it up, and sound was only coming through the right ear. Seemes like a loose connection to me, because when the I have the phones half pluged in, I can get sound through both ears. Normally I would send the unit back to the manufacture, but I'm living in
    Uganda at the moment, for the next 5 months. Anyone got any tips?
    :lease: thanks,
  2. vtah236
    vtah236
    Jul 25, 2005
    89
    9
    Try another set of earphones. If it still doesn't work then you know it's definitely the player's fault
  3. KJ_Palmer
    KJ_Palmer
    You could try some contact/switch cleaning spray. Though that may be somewhat hard to come by. Or isopropyl alcohol...
  4. redherring
    redherring
    yeah, ive tryed another set of phones. Does anyone know how you take one of these apart so i can poke about inside?
