broke glass on green tube need help
Discussion in 'Projectors, Screens & Video Processors' started by patt, Apr 5, 2005.
  1. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    Hi need some help after taking the tube out of my 701 draining the coolant down i broke the 5mm glass on front cutting the sealant now can i get a 6mm one cut from standard glass i say 6mm become this is all the glass man has also why would the fungus come back after 300 hours as i did the red 3 months ago thanks
  2. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Usually this is not a fungus (unless it is green) as such but a crystal forming as a result of the aluminium being exposed and reacting with the fluid. If you scrapped away any of the paint as a result of cleaning it is important that you repaint or the white crystals will keep coming back
  4. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    Thanks roland but is standard glass ok to use
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    As far as I'm aware it's ordinary glass
