Do you think it could cause the noise? I'm just about to sit down and have a play..
Well the power lines are out... Tested for an hour... Seems fine...
No idea re frequency but the fact the powerlines are removed and it's working fine is great news..Would it normally occurred in that time period, what would the normal frequency be?
Yep meant would you expect it to occur in the hour or is out less frequent. Great though of that has resolved itNo idea re frequency but the fact the powerlines are removed and it's working fine is great news..
Sorry mate thought you meant the powerline speed haha... Hopefully it's fixed but I'm at work again... Watch this space. Normally I get about ten an hour... Or maybe moreYep meant would you expect it to occur in the hour or is out less frequent. Great though of that has resolved it
I don't need to... I've removed them and it's stopped... I need to test it all further but I've been working non stop and haven't watched loads of tv... I'm off all weekend though so can double check everything thenNoises stopped!
Now put Powerlines back in/on and see what happens. That should prove they are the cause of it!
When one is off there's no blip
I have my TV and soundbar on a 6 plug tacima mains conditioner which is connected to a belkin surge protector on the socket.
Yeah there's no noise from outside..I live on a riverside estate...but there's powerlines about 200m away... Thought it could have been that but nobody else on my estate has had any issues.Yes, Im not surprised to read that.
Injecting internet comms and the like into the AC in your house/flat/whatever is a sure way to get interference on anything AV.
The simplest approach is to remove it all and hard-wire everything. Of course if you want to retain the convenience then youll have to "protect" the AV equipment with quality filters and shunts and that costs a bit. See Vertex AQ Roraima, Taga and Jaya. The everyday items available in the high street and elsewhere are poor in this regard, in my opinion.
On top of all of this "noise" there are all the Switch-Mode Power Supplies found in just about all AV and Computer equipment that themselves inject EMI/RFI into the AC Mains. Plasma displays are likewise "noisy".
Then theres your fridge/freezer compressor and boiler pumps, more "noise".
And possibly your neighbours with their "noise". Of course you may be lucky enough to live "out in the sticks", in which case this additional/external "noise" may not be present.
As you can see, theres quite a lot to deal with here, but the "noise" can all be successfully eliminated and possibly more importantly, once done, you will notice a distinct improvement in audio reproduction across the board. With a full complement of Vertex AQ devices installed I am still very impressed with the improvements obtained. So that youre aware, I have no connection with Vertex AQ whatsoever, I am simply giving my personal opinion.
Haha I know!!! It's like I've got a Bermuda triangle for electronics here... The mains conditioner is meant to sort out stuff like noise.Is that the same for each one. i.e. is it only one that is "faulty" or both?
And previous sound bars have had the same issue so it would suggest that whatever the particular powerline adaptors are doing can't be filtered out by the onboard electronics.
Well the mains conditioner is doing much to stop it ...
I've noticed that a lot of bars over the years have had a blip issue..I've had five bars though and they all did it..I've changed cables... Equipment..had the mainboard replaced in my TV... Total pain....Is that the same for each one. i.e. is it only one that is "faulty" or both?
I've bought a tp link mesh system now..m4... Much betterDo you think it could cause the noise?
