BROADBAND Please help me out
Discussion in 'Networking & NAS' started by BrynTeg, Aug 3, 2006.
  1. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,352
    167
    Cardigan Wales
    +2,111
    i have orange 1mb service, when i run a speed test all i get is
    Downstream 338.7 Kbps ( = 0.3 Mbps )
    Upstream 239.9 Kbps ( = 0.2 Mbps )
    somethings up here,can anyone advise in simple terms how i can speed the damn thing up?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +271
    You need to run the speed tests to make sure that the low speeds are not just due to high traffic loading at your exchange at certain times of day. If your speeds are consistantly low, try plugging your ADSL modem directly in to the phone master socket, with all other phones, faxes, Sky boxes, etc disconnected. All of these items (with the exception of the ADSL modem) have to be connected via a microfilter.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
  4. signs
    signs
    Nov 28, 2005
    21,490
    nr burton on trent
    +3,317
    Thanks for the info above (from Mrs Signs) we have been having problems with our connection since upgrading to 2mb and the kitz.co.uk website link has really helped me, (it's packed full of useful info etc.) hopefully we can now correct our problems and run smoothly :smashin:
  5. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    If you're on ADSL, speed will be down to distance from the exchange, the contention rate of your ISPs service and as previously mentioned, the time of day.
  6. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    You may also want to have a look here: http://www.adslguide.org.uk/ and also try using different speedtesters from time to time. Particularly try using the BT speedtest to rule out any ISP problems. Instead of logging on to your ISP as normal change the login details to [email protected]_domain, leaving password blank, connect and go to http://speedtester.bt.com and follow instructions for the speedtest.
  7. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,371
    BT actually recommend that you use this site to test your speed.
  8. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    I've used that site many times and it can be extremely variable.
  9. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Yes I scratched my head for nearly a year until I found this site, then all became clear!
    Pity BT weren't as helpful!
    Rejigged the internal wiring which bought a few extra vital db of SNR margin and it has made a big difference to stability of the connection.
