Broadband declined !! what now ?
Discussion in 'Networking & NAS' started by Browner, Mar 11, 2003.
  1. Browner
    Browner
    Hi guys,
    I have just found out that I have been declined for broadband :mad:
    I signed up with Plusnet, all looked OK, postcode checker said it should be OK. They have come back to me saying BT have checked the line and it has losses of 56.4dB, the max being 55dB.
    That does not sound a big deal, anyone know what the scale is and how bad it would effect service.
    Plusnet have said contact BT to see if they can optimise the gain ??:confused:
    Any suggestions ? If I try and sign up with BT, do you think they would "make more effort"??
    Used to have blueyonder :smashin: but recently moved, HATE dial up :suicide:
  2. selexus
    selexus
    Browner,
    You may still be able to get ADSL.
    If BT are still not happy with your current line try getting a new line installed. make sure when ordering that you state that this is for ADSL and if the line doesn't pass the BT ADSL tests that you won't be paying a damn thing (not fit for purpose etc). This is what i did.
    Also try asking about RADSL this is rate adaptive ADSL i.e. bandwidth negotiated. The speed will be less that a full ADSL line but the distance is another 2km on top of the max 3.5km for a normal ADSL.
    HTH
  3. acs1
    acs1
    Aug 28, 2002
    Hove
  4. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I can sympathise - I'm in the same position. I've tried hassling BT, but they don't seem to want to budge, although I don't have the result of a loss test. I've not had them offer to try and improve things.
    I've kind of given up, and am waiting for this "midband" thing to come out - supposedly in the spring. It will be 128K "always on", and that's about all we know - no-one seems to be sure if it's a xDSL thing or home highway with knobs on.
    Incidentally, did your number come up OK on BT's checker ? It seems to be more accurate than the ISP's ones. My number came up OK witrh a couple of ISPs, but not on that.
  5. alextgreen
    alextgreen
    Apr 17, 2001
    545
    London
    +5
    We had the same problem, got it in on my dad's new business line instead.
  6. Browner
    Browner
    Thanks for info and link guys.
    Yes, even the BT checker said it "should be OK".
    Have posted the same question on adsl.org, :smashin: good site. Came up with similar answers.
    A comment on ADSL.org was that BT will be raising the limit of losses to 60dB :clap: sometime in the near future.................
    If that date is not known or too far away I will contact BT to get a new line put in, especially for ADSL, on the condition if it doesnt work I'm not going to pay.
  7. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    Don't want to put a downer on your plans, but if you ask for another line to be put in just for ADSL, all you will get is a standard PSTN which will be tested once fitted to see if it will carry ADSL. Is your house fed from pole or underground? a new line will come along another pair of wires in the exact same cable as your existing line, unless you are fed overhead, ie from a pole, in which case the dropwire my be a letting the line down, check to see if it looks like bell wire.
    Unfortunately, if your line is not up to ADSL, BT are very unlikely to do anything about it, most of the problems are with old aluminium cable in the ground. What part of Bristol are you in?
  8. themadhippy
    themadhippy
    and if you wish to test the line yourself dial 17070
    optionsr 3,1,2 hang up and let someone else answer the call back
  9. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    Unfortunately that will only tell you the line length and capacitance. No help for an ADSL test.
    AND it is for BT use only :nono: ;)
  10. themadhippy
    themadhippy
    so much for computer shoppers advice them
  11. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    To be honest, if your line doesn't test OK with 17070, you'll be lucky to get a dial-up connection much over 28k never mind ADSL.
  12. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    There have been suggestions that if you apply for BT's ADSL they will do what is necessary to get your line working. For other providers they just do the check and give a yay or nay response. Now if this were me... :devil:
    p.s. I thought all lines are now RADSL by default.
  13. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Sadly, this doesn't seem to be the case. I tried that, and they just came back with their standard "no can do" response. I asked whether it was possible for them to test my line individually, but was told that eac hline had been tested when the exchange was enabled (not sure I quite believe that, but anyway....
    Any other suggestions?
  14. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    Your right, even if you sign up for BT's broadband service they still won't carry out any work to improve the quality of your line.
    RichardH I guess you must either be too far away from the exchange, or the exchange is not ADSL enabled, or you live in an area with known poor line plant.
  15. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I did the 17070 thing and got the line length info back. 5.53km. Yes, 30 METRES too far (all other things being equal). Hence my attempt to get BT to do something. I can only assume that they're seeing the line length is over 5.5km, and saying no. Trouble is, I didn't think it was a particularly good idea to tell BT that I'd used that test and what the result was :rolleyes:
  16. acs1
    acs1
    Aug 28, 2002
    Hove
    RichardH, I was 5.7km away from my exchange and was turned down by BT, but applied with Freeserve and got accepted. I know it is BT that do the checks but it is left up to the ISP as to whether they accept you or not.
    Had my broadband for about 6 months now
  17. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Well, I might give them a shot, then. Thanks for that one....
    EDIT:
    Bah, just tried applying for Freeserve online, and the line checker told me I was too far away....
    R
  18. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    There are is ReachDSL long distance for distances greater than 5km from a BT exchange & RADSL Broadband , ADSL Broadband have A look here
    hope it helps
    :clap:
    Boogie man
  19. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Looks very hopeful. I've mailed them, so we'll see what comes out. If it ends up with me getting broadband, I'll come round and snog you, boogie man :clap:
  20. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    With NTL, if the (TV) cable to your house is too long and has too much noise on it, they will replace it with better quality cable... do BT do such a thing, or do they use the same crappy unsheilded copper cables for everyone?
  21. mortuk
    mortuk
    Thought about "cable" broadband? Blueyonder go up to 1 Mbit for £35 a month..
    MortUK..
  22. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Cable broadband - if only. The local town (3 miles away) has NTL, but we're in a small village. Can't see us ever getting cable, TBH.
  23. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    I Found u2menet tel no. 01256693089 there in basingstoke i got to phone aswell looking at RASDL 768/7M FOR £70
    boogie man:clap:
  24. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I'll be on the blower tomorrow morning! I'm not going to get my hopes up yet, but they look as if they'll at least make the effort to try.
  25. Browner
    Browner
    Update:
    after phoneing BT:
    1st person, did'nt really understand my problem with line loss of 56.4dB etc, ended up ordering BT broadband for me even though I said it has been checked and declined by BT, but on his screen there was an amber light. If somehow accepted I will cancel and xfer straight away.
    2nd person very good, confirmed that BT were testing lines with 60dB loss, expecting new limit to be introduced in the summer.
    Then said that BT have caught on and would not install second line FOC if still didnt meet requirements of ADSL.
    So thanks all, will now wait for BT broadband to decline me, and looks like I have to wait until the summer.
  26. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Boogie man - that Reach DSL company you found (u2menet) isn't actually operating yet - they're hoping for May.
    The wait continues.....
  27. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    RIGHT THEN. Now I'm confused. I did the 17070 line length test thing a while ago, and it came out at 5.53km. Did it again today, and it's now 5.47km. Does cable shrink? Or maybe someone's rerouted cable at the exchange.
    Trouble is, I can't get past the BT stonewall of "you're too far away"
    :mad: :mad:
