Broadband/ADSL Modems
Discussion in 'Networking & NAS' started by d_devani, Mar 12, 2003.
  1. d_devani
    d_devani
    I am planning to get ADSL broadband at home, I want to get the modem myself as the Companies are charging loads for them.
    All I want is to connect 1 desktop to the net, maybe have a continous connection.
    What sort of Modem do I need,
    Combined ADSL Modem/Routers
    Wireless Access Point
    USB ADSL Modems
    Specialised ADSL USB/Routers
    What are peoples thoughts on
    ADSL Modem - Alcatel Speedtouch 330 USB
  2. nathan_silly
    nathan_silly
    Get a router/gateway. You don't need any drivers at all, plus it doesn't hog the host PC (USB ones do)
    I thought about getting a bog standard ADSL modem, my Netgear DG814 is a little more expensive- but it's got a 4 port ethernet hub (they're worth £25) Haven't looked back. Happily pay £200 for the same unit (cost me £120)
    [edit] noticed you've only got 1 PC- I would still recommend a router- your mate could bring his PC round and play deathmath, maybe in the future you might get a cheap laptop. Plus still no drivers required. And some extra security- routers have built-in NAT/VPN, Modems are totally open and will need firewall s/w without a doubt.
    I usually have one PC connected, but it's still easier with a router.
  3. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    As Nathan said the Netgear DG814 is excellent - If you fancy getting one ebuyer have them at a good price.
