Brightness / Contrast settings for A300?
Discussion in 'Projectors, Screens & Video Processors' started by Captain chaos, Jul 10, 2003.
  1. Captain chaos
    Captain chaos
    Just as a kind of rough guide, what are you guys running your contrast and brightness levels at on your A300's?
    Cheers.
  2. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Using other peoples set ups is not a good idea, unless all components are the same i.e Screen, DVD Player, Connections and lighting.
    You should set your system up using a calibration disc for best results. ;)
  3. Captain chaos
    Captain chaos
    Is that one of those AVIA disks that costs an extortionate amount of money?
  4. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Certainly is, but it will calibrate your picture the way it is supposed to be :) Im afraid its the only real way to calibrate your projector.
    Video essentials is good too (not as good as AVIA though). The new version which is yet to be realised should be available in PAL format as well.
    :smashin:
    Also some DVDs have the THX optimizer program on the m, this would help you to setup your contrast (My AnchorBAy Evil Dead DVD has this little prog)
  5. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    These have appeared on the american forum. I noted these down as i'm in the market for a 300 soon.
    There are 4 different ones....the first one is an Avia set up.
    no 1
    Mode:Normal
    Contrast:+4
    Brightness:-2
    Colour:-4
    Tint:+3
    Sharpness:-3
    No2
    Cinema2
    contrast+2
    brightness-1
    colour0
    tint+2
    colour temp+1
    white gamma0
    black gamma -15 to 2
    no3
    cinema 1
    contrast 0
    brightness -18
    colour 0
    tint 0
    sharpness 0
    contrast red 0
    contrast blue-3
    brightness red +4
    brightness blue +1
    Gamma adjust : white level -3,black level 0
    no4
    Mode normal
    contrast +5
    brightness -10
    colour -5
    tint 0
    sharpness 0
    color temp 0
    Gamma adjust: white 0, black -1
    Look forward to hearing which one works best.
    Regards Pal
  6. Dekim
    Dekim
    Feb 9, 2002
    293
    Hi Captian chaos,
    I set mine up using the Avia disk but was not impressed with results. I had the DVD feeding both the AE300 and a 36" CRT. I was astonished how much detail was missing in dark scenes. I had to adjust brightness, contrast and color tint away from Avia settings to get a better picture. I'm at work so cant access my setting but I think I currently have contrast 6 brightness 3
    I am using Phillips 963sa DVD thru component / Pal progressive.. Obviously my settings are relevant to this DVD.
    Deks
    ps forgot to mention the scene I used as comparison was from Blade 2 which does have a lot of dark scenes
