Brightness Change
Discussion in 'General TV Discussions Forum' started by Vinesh, Jan 5, 2003.
  1. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    When watching DVD's, I find the brightness of the screen changes from normal brightness to slightly darker. This only happens on certain DVD's, ie 20th Century Fox, certain R1's.
    Current Equipment:
    Pro-wire S-video to S-video cable (TV to DVD)
    Tosh 28" TV (6 Yrs old)
    Any Suggestions?
  2. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Is there a better way to connect the above?
    S-Video to S-Video (DVD to TV) 1.5 metre lentgh. This will be changed as it is over-strecthed abit.
    Digital Coax (DVD to AMP)
    Cambridge Audio L+R Interconnects (TV to AMP)
    TV Connections:
    S-Video
    Scart
    Componet Video - I think (Need to make sure).
    DVD Connections:
    RGB, S-Video, Composite AV
    S-Video
    Composite video
  3. jim.rae
    jim.rae
    Do you have the black level control switched on in your DVD menu?
    Some TVs also have the same facility.
    That could change the brightness at times when it can't cope with the picture it's trying to keep the blacks dark on.
    As far as connections are concerned - for the pictures component would be first choice - if you have it - if not, RGB is almost as good and sometimes less difficult to calibrate depending on your kit.
    Have a delve in your DVD and TV menu to see if you have black level clamping and switch it off...
  4. jim.rae
    jim.rae
    PS - Make sure you mean component and not composite, as a six year old TV is not likely to have component in...you know the one that uses three phono style leads for pictures...
  5. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Thank you for pointing that out. :)
    Component and not Composite
  6. jim.rae
    jim.rae
    That takes us back where we started - checking if there is a black level control somewhere in the system that's causing the problem...
  7. Squirrel God
    Squirrel God
    If it only happens on some DVDs, then it's the DVDs that have a dark transfer which is down to a whole host of reasons. I have some DVDs that I think have a particularly dark transfer or are lacking in contrast compared to others (e.g. American Pie).
    In this case, don't touch anything. There's nothing wrong with your TV.
    If this "darkness" happens on all DVDs, then it might be the way you have it connected. Try a good quality Scart instead of an S-Video cable if you can.
    In all cases, calibration via a test/set-up disk is a good thing and should be done anyway.
  8. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Thanks for the replies. I will check the settings.
  9. YellowCows
    YellowCows
    Dec 15, 2002
    141
    Also, check the Toshiba Picture settings menu (the first menu page). If it has an entry called 'Black Stretch', switch it to OFF.
    In the future, look into a system-calibration DVD, such as Avia or Sound & Vision to optimise your display settings - that way, you'll always have the best possible picture.
    If your DVD player has component-outs, what are you waiting for? USE THEM!
    Some DVD's are darker than others, though - in which case, it wouldn't be a fault with your telly.
    Moory:)
  10. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
  11. jim.rae
    jim.rae
    RGB by SCART is indeed better than S Video in most instances...
  12. Doubledoom
    Doubledoom
    Toshiba widescreens from 6 years ago did have component input on many of the models.
    Also, Toshiba sets of that time tended to suffer poor RGB implentation and usually offered a better picture using s-video.
