Bright Yamaha RX-V2700 and Monitor Audio Speakers
Discussion in 'Cables & Switches' started by P1_Chris, May 3, 2007.
  1. P1_Chris
    P1_Chris
    I have just spent weeks deciding on what speaker cable to buy and it helped me to decide by reading other peoples thoughts on here - so:
    On buying a new AV system with a Yamaha RX-V2700 and Monitor Audio speakers, I had it all wired up using Cable talk 'talk3' speaker cable from my old hi-fi system.
    When I first listened to the system - to say I was a bit disappointed with it was an understatement, I really did think I had made a mistake with pairing the Yamaha with the MA speakers - not a great deal of bass and it all sounded a bit 'cluttered' at higher frequencies (if you get what I mean).
    Anyway - after much deliberation I bit the bullet and spent (what I consider - a fair amount of money) replacing my Cable talk3 cables with some new Ecosse Cs4.45 bi-wire cable (I also switched to bi-amping the fronts using the Bi-amp option on the V2700) and I am very very pleased with the sound output now.
    I am not one for explaining 'how' it sounds better but it just does, so much so that I spent a good few hours listening to CD's last night which I havn't done for ages!!
    I was initially tempted to go for QED silver XT cable (or similar) because of the good "What hi-fi reviews" etc, until reading lots of posts about silver cable being 'bright' so after much searching went for the Ecosse.
    I also got some Cs2.3 for the centre speaker and now the surround sound is stunning on it, I havn't got a subwoofer but the bass to me from the RS8's is fantastic - makes the settee tremble!! - so all in all very pleased with the amp and speakers now.
    For those interested the cable cost £159 for 2 x 5.5 mtrs bi-amp/wire Cs4.45 for the fronts and £40 for a single length 4.5 mtr Cs2.3 for the centre.
    To be honest this is the first time I have spent so much on cable but worth every penny so far!!
    If you email the company and ask for quotes first they seem to do it a bit cheaper than phoning - I dealt with Elliot the MD who was a great bloke - offered lots of advice about speaker cable length but balanced with cost and return etc.
    When I get a few more pounds saved up I might replace the rear cables with Cs2.3 as well but need 12 mtrs for one of those!!
    By the way - I have no connection with Ecosse cable company just like to mention when I find a firm that is good and they are British!!!
    Chris
  2. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    All down to a bit of wire a! :thumbsup:
    Have you played with your IC's yet:)
  3. P1_Chris
    P1_Chris
    Deaf cat,
    I bought a pair of IXOS digital co-ax cables for the interconnects between CD / DVD and AMP.
    Can't really comment on DVD --> AMP as that is all I have used for surround.
    The CD I really felt the digital output sounded worse than the L/R Analogue o/p's from the CD player so I resorted back to those. Will have a play in the coming weeks as I am just using a cheap analogue lead (ie free one) so will order another and report back.
    Using a profigold component cable for video from DVD to AMP and that works well with good picture quality on 720p upscaling.
    Chris
  4. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    :smashin:
    If I'm right in thinking RCA IC's and RCA Digi coax cables both operate at 75 Ohms.
    I know I've been meaning to try my one of my IC's as a digi cable for a while now. Better check thats right, then you could try your new pair of digi coax's as an analogue IC from the cdp, just to see what sound they give :)
  5. P1_Chris
    P1_Chris
    Interesting suggestions there - I will give it a try and see what results I get.
    Chris
