Bright sound from monitor audio
Discussion in 'Home Cinema Speakers' started by lip sync, Feb 3, 2009.
  1. lip sync
    lip sync
    Dec 6, 2007
    45
    Hi all
    i have A Denon 4306 and monitor audio 8's for L&R with SFX for the rear and a gold centre. (i have also tried with the silver centre)
    my problem is that the sound always sounds a tad bright, i have run through the audesy and also tweeked back on the tone control?
    any ideas?
    i am using silver aniversry xt bi-wire and am considering switching to Chord Oddesy biwire for LR and C
    does anyone outthere have any joy with QED SilverAniversary-XT
    or would the Chord take the edge off?
    thanks
  2. beckzito
    beckzito
    Oct 26, 2005
    124
    Portugal
    +15
    Well, you can change cables but my guess its that you would be wasting time and money.
    As far as i know equipment from MA and Denon they both tend to that bright feeling you´re hearing.
    I would stick with it untill the time i can change one.
