J
jaredg27
I've searched through much of this site, and gotten a good feel for the various projectors. And, even though I already own an InFocus LP500 and have used it to varying degrees of success in rooms with windows, I have no concept for whether a projector will be substantial for playing television/movies in the living room of the house I'm moving into next month. So I'm hoping to learn more about your experiences with brightness in fairly bright rooms so that I can recognize whether buying a projector for this room is just a bad idea. I hope that other newcomers to this site will also be able to benefit.
My specfics: the room has 3 windows, two of which would be directly to the right and left of where the screen would be located (above the fireplace), and the other which is a double window on the wall perpendicular to the projector wall. I'd put up a screen above the fireplace for the image, of course. Here's a picture:
Thank you again for any help. I'm curious if I should toss out the idea of a projector...or, should I get one, how many lumens I'd need to consider.
Thank you!
Jared
Thank you!
Jared
