Bright GREEN Flickering Pixel
Discussion in 'Plasma TVs Forum' started by MrRee, Sep 9, 2007.
  1. MrRee
    MrRee
    Jan 15, 2005
    11
    HELP!!
    Bought this LG Plasma on 24th March this year.
    After about 3 weeks I noticed a bright green pixel ....... it didn't show when a light colour or white was displayed.
    Due to a mixture of holidays, laziness and the fact that I thought I would be laughed at by Currys I didn't do anything about it.
    I think it may be called a 'HOT' Pixel??
    Well, now it is burning REALLY brightly - flickering in fact - BRIGHT GREEN and it's really annoying ......... the position couldn't really be much worse as it is about 66% up and 66% across the screen!
    I have contacted Currys who looked on their computer and they say they know what the problem is and I will have a new PCB fitted this week ....... good service, if it cures it.
    BUT, this is where I have a question ...... will a PCB change fix a hot pixel??
    I am guessing that the panel is faulty, not something to be cured by a new PCB??
    I hope that it can be cured with a simple PCB change - whats your thoughts??
    Thanks in advance.
  2. delphiplasma
    delphiplasma
    Aug 17, 2007
    85
    Did the PCB cure the fault?
