Bricked my iphone?
nstokes
i upgraded to ios 4 i didnt like it so tryed going back down to 3.1.3 and pressed **** and then restore, choose the 3.1.3 fw it came up with an error afterwards so tryed agaian then the phone just went to a blank screen and stayed there for ages, so i unplugged the phone from usb and had to alt+ctl+del itunes and now the phone comes up with the itunes and usb cable icon and itunes wont see the phone. the pc makes the noise to say plugged in and unpluuged. i have tryed the dfu thing and just comes to this screen no matter what i do itunes will not see the phone. What can i do to fix this? is it now 100% dead? is it bricked?
nstokes
its out of warrenty i got it as a recon from o2 last april, is it worth trying on another machine?
nstokes
jerryq7777
You can't brick an iPhone. Dfu mode will work, you will be timing it wrong.
I think you will find you can brick it.The phone goes into a reboot loop and nothing works to restore it.
nstokes
i keep trying dfu and thae screen ive discribes is all im getting, what should i get for dfu mode? whats the timings? jerryq its not in a rebooting loop (thank god). Normally i no how to do all sorts with the phone but this is the only thing i cant do with it at mo (getting it to work) i realy hope i havent bricked it
jerryq7777
Apart from the fixes that are all over the web. You can't brick an iPhone, there is always a way out.
irecovery or ibricker i tried both and they still didnt fix my phone.
nstokes
i still cnat get it working, im holding the buttons in, it comes up with the apple logo, then goes to itines and usb cable icon and then the screen flases white and goes blank (im guessing it tured off) i then let go the power/wake button and holding in the home button, still a blank screen and no pop up on itunes
SteveU30
Try reinstalling iTunes, restarting the PC and then plugging it in.
Saxo Appeal
Where are you sticking the usb cable into?
If its the front try using the back usb ports into the computer...or vice versa
Could be dodgy or messed up ports
Saxo Appeal
Ok
Is your phone going on and you can use it?
What messages are you getting on the screen?
Is it iTunes that isn't working or the phone?
Have you updated iTunes?
Try a different usb port
I had problems like this, how many people use the computer to connect to iTunes?
It doesn't seem like the phone is bricked, it's like the computer isn't recognizing the phone is connected even though you hear the noise
scudder
or try another PC altogether, often the PC gets minced with too many attempts. If using a different USB doesn't work, try using a fresh PC if you have access to one. DFU and restore or RecBoot should sort your brick out.
nstokes
below are the answres to your questions
Is your phone going on and you can use it? - Going on and off but cant use it
What messages are you getting on the screen? - No messgaes just the itunes and usb cable icon on phone screen
Is it iTunes that isn't working or the phone? - Could be both
Have you updated iTunes? - Yes im using 9.2
Try a different usb port - Tryed front and back
Try reinstalling iTunes - I have done but i will try again just in case
I had problems like this, how many people use the computer to connect to iTunes? - None just me
It doesn't seem like the phone is bricked, it's like the computer isn't recognizing the phone is connected even though you hear the noise - I will try another compute
nstokes
going to try another computer later on
Saxo Appeal
Are you all up to date with your Anti virus etc? Could be a corrupt file that isn't allowing your iTunes to run correctly even though your reinstalling
Fizzy12
Have you tried opening itunes with phone unplugged, holding down the home button whist connecting to the computer and holding till a message comes up about restoring?
This worked with my phone, but wouldn't work on my computer, had to do it on my friends, which unlocked it then just had to do a restore on mine.
HTH
akki007
HTH
Yeah, I think this should do it too.
nstokes
HTH
i didnt try this but i have just tryed it and same thing. tryed doing it on 22 diffrent us ports (1 front and 1 back) my av is up to date. it it helps it takes about 5-6 secs from the apple logo to get to the itunes and cable icon. that seems quick?
Fizzy12
Like I said it won't work on my PC for some reason no matter which usb port I use but did work on my friends so try it on a different computer :)
nstokes
going to the old mans later so i will try it then and will report my findings as they say. Thanks for the help guys and like i say oill post what happened later on (after the england game of course ;))
