Brazil-R1 Criterion - picture ratio
Discussion in 'Movie Forum' started by raigraphixs, Jan 17, 2003.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    57,677
    +20,187
    I just wanted to check the format of this film. Its labeled as 1.85:1 on the box, but it's in 2.35:1?, is this correct. Seems a huge oversight for a criterion SE boxset, can someone check? I havent watched film yet (see it years ago), but there were black borders when i tested it.
    many thanks
    rai
  2. Rambo John J
    Rambo John J
    Aug 11, 2000
    4,487
    Hanoi Hilton
    +1,613
    My widescreen vhs is 1.85:1 if that's any help (probably not)
  3. Squirrel God
    Squirrel God
    You can check the original aspect ratio at www.imdb.com - just search for Brazil and click on technical specs from the menu on the left.
    Out of interest, where did you pick it up from and how much was it?
  4. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    Brazil is 1:1.85
  5. raigraphixs
    raigraphixs
    Jul 11, 2001
    57,677
    +20,187
    Hi Squirrel,
    Got it from cd-wow for £29.99.
    Wonder why mines not in 1.85:1?. I have to try it again.
    its the final 5th version of brazil, the directors cut.
    rai
  6. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    The Criterion edition of Brazil is definitely 1.85:1 (non-anamorphic).
  7. raigraphixs
    raigraphixs
    Jul 11, 2001
    57,677
    +20,187
    So there should be no thick borders on a widescreen telly?
    rai
  8. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    You're probably watching it with black borders AND short and fat people, aren't you?
    Set Aspect to ZOOM. Problem solved. :D
  9. raigraphixs
    raigraphixs
    Jul 11, 2001
    57,677
    +20,187
    Sorry Grubert but i did not understand what you mean?
    My tv is set to widescreen.
    Just read back of the disc 1 box and it says ''Letterboxed in its proper aspect ratio (1.85:1)".
    Now 'letterboxed' means borders does't it?. So whats the difference between a 2.35:1 and a letterboxed 1.85:1. ?
    I dont mind the borders but I was always lead to believe 1.85:1 was full screen and NO borders., unless its letterboxed 1.85:1 like my brazil dvd, right.
    ta
    rai
  10. Mundos
    Mundos
    Generally if the packaging says that a film is letterboxed then that means it is a non-anamorphic transfer, so to see the film in the correct aspect ratio on a widescreen TV you need to use the zoom mode (which in the case of a 1.85:1 film makes the black bars all but invisible). If you are watching the film on a 4:3 TV then you will see the black bars top and bottom.
