Bravia S-video problem?
Discussion in 'LCD & LED LCD TVs Forum' started by tall.small, Aug 6, 2006.
Tags:
  1. tall.small
    tall.small
    Oct 4, 2002
    98
    Kings Lynn, Norfolk
    I've just got a Bravia KDL40V2000 and I am having problems connecting my Panasonic SCDT100 home cinema DVD player to it. The DVD connects through S-video only and on my previous TV, a Panasonic TX28PL1, I connected it through AV2 but the TV had an option for AV2/S which would change the picture from B&W to colour. I used a good quality S-Video to Scart cable.
    However when I connect the same DVD and cable to the Bravia through AV2 the picture is black and white and I cannot find anyway to change it to S-Video.
    The Bravia's S-Video socket is AV5 but I do not have the S-video to S-video cable required.
    Is there anyway I can use the AV2 on the Bravia and change it to AV2/S?
  2. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    SCART sockets can only be wired up as either S-Video or RGB - both on the BRAVIA are RGB. (so they have double the colour resolution) The AV2/S thing is toggling between composite and s-video.
    You'll either need an S-Video lead, or you might be surprised with the quality from Composite, I hear the BRAVIA has a great comb filter.
    You should really be connecting up your DVD player via RGB at the very least though.
  3. tall.small
    tall.small
    Oct 4, 2002
    98
    Kings Lynn, Norfolk
    Thanks for the reply, much appreciated :)
    I've just bought a decent S-Video to S-Video cable from a fellow AVforums member to do the job.
    Really quite surprised there is no way I can get a colour picture with my existing setup though. Didn't realise the Bravia wouldn't be able to do it. No problem though.
