Brand new Z3 not working, any ideas?
Discussion in 'Projectors, Screens & Video Processors' started by Ciaran500, Dec 17, 2004.
  1. Ciaran500
    Ciaran500
    I recieved my Z3 this morning, when I plugged it in nothing happened. No flashing lights and no power light. I tried 3 different plugs, the cable is properly into the back of the PJ and the power switch on the back is in the on position.
    I rang the retailer and they said they had done a stuck pixel check before the shipped the PJ so it was working before it left. So it was probably damaged in transit, so I will have to return it on monday. :(
    Any ideas on something I could of missed?
  2. Comer
    Comer
    Sep 21, 2001
    1,385
    Ireland
    +85
    If you plugged it in and switched on the powerswitch, I would say it needs to go back.
  3. Ciaran500
    Ciaran500
    Thats what I'm afraid of, hopefully I'll have one by Christmas.
  4. Comer
    Comer
    Sep 21, 2001
    1,385
    Ireland
    +85
    Oh yea, check the fuse in the powerlead, unlikely but u never know. They may have used their own powerlead doing the pixel check
  5. Ciaran500
    Ciaran500
    Thats the first thing I checked, I even got a multimeter and checked that power was getting up the lead. No problems found. :(
  6. Ciaran500
    Ciaran500
    Is there any easy to get to internal fuses or anything similar that I should try?
