Quantcast
Brand new OLED 65" frozen on dashboard screen; unable to reset
LauraCF
Our brand new 65" LG OLED tv has frozen on the Home Dashboard screen and nothing we have tried will reset it.
If we can't get it up and running again, it's going back, no matter how much we love the picture.
Advice much appreciated, thanks.
sagaris99
Assuming you’ve done a power cycle, off at the wall for 20 mins, turn back on etc?
next step is hold power button on back of tv for 30 seconds
hope it fixes itself overnight🤞
LauraCF
Unfortunately, no overnight fix. We've tried the system reboot, television off, all of the normal things you'd do. The mouse on the remote will move around on the screen, but selecting an item does nothing. It's as though the muse won't intereact with the screen.
Our neighbour, using a different remote, was able to get the TV system updated, and we were hoping that would do it, but as soon as the update was finished, we were back at the Home Dashboard, unable to interact with the screen.
The mouse has brand-new kbatteries, so that isn't it.
It's frustrating, because the whole system was working perfectly three days ago. Then it did this. Now we have $3,000.00 worth of junk.
Should've just bought another Samsung.
sagaris99
The remote they use, is it a magic remote or a normal IR remote? and does their remote work at all?
my sympathies, not what you want after dropping a fair chunk of money and got excited to use it
not much consolation, but motherboard failures and software bugs (which this sounds like) are just as likely to happen with any brand.
where do you stand with the retailer? I’m unfamiliar with consumer law in Canada.
LauraCF
No, wait, you were correct!
The one thing we didn't do was hold down the power button for 20 seconds, and it worked. Thank, thank, thank you!
I wasn't sure whether my reply below got posted...there was an error message.
Anyway, we had NOT held down the power button for 20 seconds, and that solved the problem, so thank you so much! Peace now reigns in our home now that DAZN is once again available.
Just BTW, we bought it at COSTCO, and they are excellent with returns. We would have had no trouble returning this TV.
Again, thank you!
sagaris99
Again, thank you!
No worries at all, glad to hear it’s come back to life! Yes, the power button reset is hail Mary, but always seems to work
enjoy :clap:
Similar threads
