My front brakes need replacing on ym 2003 Peugeot 206 GTi 180.
They are currently 283mm vented disks and performed very well but have now started juddering slightly under braking and have lost the usually bite.
I have had a look around and can get normal disks for £75 + pads for around £25
Black Diamond - drilled/grooved disks with Predator pads and braided hoses for around £250
Or......
Hi Spec 4 pot big brake conversion with 285mm drilled disks, braided hoses and green stuff pads. This lot comes in at £650 which seemed quite reasonable for 4 pots.
I do quite a bit of city driving, starting/stopping and sometimes like to put my foot down a bit.
Would the 4 pots really be worth it I've had a few little bits done and with an independant rolling road I got 203bhp at the flywheel but only 168 lb/ft torque.
Thanks for any opinions or comments.
Mark
Or......
Mark
