Brainwave v880 - 720p/DVI wo HDCP
Discussion in 'Blu-ray & DVD Players & Recorders' started by tapani, May 20, 2003.
  1. tapani
    tapani
    May 20, 2003
    Finland
    hi all,
    I got yesterday Brainwave v880 (a Momitsu clone) , which has Sigma Designs EM8500 chip inside for scaling and de-interlazing.
    PQ is excellent very near my reference HTPC:Zoom/VinDVD Platinum/FFDShow - Radeon 9700Pro.
    Positive thing is the fact that 720p works with my non-HDCP compatible projector, Yamaha LPX-500.
    Tapani
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Tapani,
    That's very interesting! May I ask where you got the player from? I've been following the threads over on www.avsforum.com on the Bravo D1 and Samsung HD931. The v880 has the same SD chip as the D1 which appears to deliver a better picture than the Faroudja chip in the Samsung. Does the v880 output 720p through the component outputs as well as the DVI, like the D1 does?
    Steve
  3. tapani
    tapani
    May 20, 2003
    Finland
    Hi Steve,
    I got it from Germany http://www.qbytes.de/ .
    It use's the same chip as D1 does, so I suspect it does 720p through the component outputs as well.
    I'm critical :) for me only the DVI is good enough.
    Tapani
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Tapani,
    Thanks for the link - €249 and multi-region too! It's getting better. Have you tested the MR capability?
    Steve
  5. tapani
    tapani
    May 20, 2003
    Finland
    I put a region 1 dvd into the machine ... I had to open the cover to get the dvd out, irritating.
    It's a mystery for me how to switch player multi-region cabable. Naturally there is no mention in the manual.
    It seems that there are some bugs in the player's firmware. For example, sometimes Eject works sometimes not.
    Tapani
  6. mr. Custard
    mr. Custard
    Tapani... I found this on AVS...
    down
    up
    down
    up
    right
    left
    Can you give it a try ?
  7. tapani
    tapani
    May 20, 2003
    Finland
    Hurrah!
    Momitsu hack does work. Now my player is region-free.
    Tapani
  8. mr. Custard
    mr. Custard
    Cool! now i can get one too ;)
  9. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    516
    16
    Aylesbury...where the Ducks live!!
    Great find....anyone know if this player works with a Sony HS10 PJ?
    Heard that sammy dvi player can do funny things to this pj....picture shift to the right????
  10. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    How does this compare with more conventional players? I've got an ageing Sony 725 connected to a Panasonic AE100 via a Pro-V de-interlacer and I'm pretty happy with the picture, but always looking to improve. I've been holding on for a DVD-A/SACD progressive PAL&NTSC player, but at this 250 euros I'd consider this player just for an improvement in picture quality.
    Simon
  11. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Does anyone know of a UK supplier with 880's?
    I've tried a couple of German places but they're out of stock.
    Paul
