Nape Dog
Hi all
I am planning on buying the Yamaha AV61 package (yamaha 3101) from pixmania. they offer a package which includes VOGEL`S VLB 50A x 2 speaker wall brackets. does anyone know if these brackets will fit the speakers correctly?
The speaker manual indicates that the speakers have holes on the back to hang on the wall which are 7cm apart but no other fittings on the back.
The Vogels website says that they bracket is 6cm. This suggests that they don't fit but I would assume that pixmania will only sell them if they fit.
does anyone have any info on this that can clarify this?
many thanks
The websites are:
http://vogels.turnpages.com/en/
http://www.pixmania.co.uk/uk/uk/550635/art/yamaha/av-3101-home-cinema-syste.html
many thanks
The websites are:
