Brackets for MS 902's?
Discussion in 'Home Cinema Speakers' started by fowlersrs, Jun 4, 2008.
  1. fowlersrs
    fowlersrs
    Feb 12, 2008
    391
    +44
  2. Upholder
    Upholder
    Feb 14, 2006
    250
    Manchester
    +23
  3. fowlersrs
    fowlersrs
    Feb 12, 2008
    391
    +44
  4. Upholder
    Upholder
    Feb 14, 2006
    250
    Manchester
    +23
  5. fowlersrs
    fowlersrs
    Feb 12, 2008
    391
    +44
    Not convinced tbh, I think the max weight the 300 brackets are designed for is 4.5, and I think the 902' are atleast 5k's..
    need something a bit more sturdy, ideally something I can hide a cable in aswell coming from the wall...
    anyone else got any ideas?
    :D
  6. TT Coupe
    TT Coupe
    Dec 26, 2006
    76
    +6
    I have the ms300 brackets and while they are fine for my aumni's (2KG's) I think they will never hold 5KG's. They are only made from plastic with a ball joint that you tighten by hand and then twist the speaker 1/4 turn.
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,275
    2
    +3,834
    Have a look at the Vogels range as they usually have a bottom clamping support that will do the job.
