Bracket with level adjustment
Discussion in 'Home Cinema Buying & Building' started by Mike-M, Jan 10, 2012.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,376
    48
    Lincoln
    +39
    I have just hung my 50" plasma on a basic tilt wall bracket. It was all straight forward and went up without problems. The only problem I now have is, because the floor has a pronounced dip from right to left the plasma looks like it's not level. As I will be fitting wall mount speakers below it, they will only add to the illusion. It's not far out but enough to be noticable and will end up driving me crazy. I have tried various ways to tweak the bracket with no luck.
    Does anyone know if there is a bracket (nothing fancy but must tilt) which allows some adjustment once it's up with the screen fitted. I don't need a lot of play, around +/- 10mm at either end or more if possible.
