Bracket for Samsung LE32A656A please
Discussion in 'Home Cinema Buying & Building' started by Bryce Curdy, Feb 11, 2009.
  1. Bryce Curdy
    Bryce Curdy
    Very grateful for any recommendations for a bracket for the above set. Fixed to the wall is fine.
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    This one will do the job;
    M-Form - 21" to 26" VESA LCD Bracket
    It says to 26" but will be fine with your Samsung 32" as the fixing points and weight are all compatible.
    Hope this helps.
    Regards
    Graham
