Bracket for Plasma TV which lowers or lifts the TV
max65
I would like to buy a Plasma TV and hang it above the fireplace. Problem is that the TV would be to high to look at.
Does anybody know if there is around a bracket which is able to move the TV forward and then lowers it?
Thanks a lot for your help in advance.
Max
MarkB2908
Hi max65. I'm looking for the same thing.
It sounds a fairly common problem, so you would expect there to be some damand for this type of mount.
Unfortunately I have had no luck....the closest thing I have identified is the CLO X ARM, which is motorized but also expensive.
Please let me know if you have any joy.
