Bracket For LG RZ42PX11
Discussion in 'Home Cinema Buying & Building' started by windfall, Mar 16, 2005.
  1. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    Guys
    Those of you that have wall mounted - which bracket did you get - and if you dont mind where and how much?
    Tone
  2. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    Does anyone own a bracket that they can reccomend?
    Tone
  3. Billyfergus
    Billyfergus
    I purchased this one here for my PX11.
    Great price and it works perfect - all sockets are left uncovered (including the scarts)
    Great price and quick delivery. Installation is very simple and everything is supplied (except the fixings to your wall).
    Get them from B & Q.
    http://www.unbeatable.co.uk/CatalogueItem_16220.html
  4. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    Hey Billyfergus :hiya:
    Thanks for your help on this one - my bracket arrived today.
    Now I am a bit of a numpty when it comes to DIY - I can do a lot but I was wondering what type of screws and rawplugs you used for attaching the bracket to the wall?
    I have plasterboard (16mm) then a 1" gap then brease block and then outside wall.
    I figure I will need something like a 4" carriage bolt?
    What did you use matey?
    Also how many hols did you use - there are two left, two right and 4 in the middle, did you use them all?
    Thanks and apologies for so many Q's! :thumbsup:
    Tone
