Box won't go to TV to reprog Samsung
Wuz
Dear all,
I have just got a Samsung LE32R73BD and have not been able to set it up for analogue TV yet.
Sky says there is no code yet but gave me some to try.
However when I try the first 5 of 19 they suggested none seem to have any effect and am still on 0060.
Problem would appear that the instruction say to start with box on TV but I cannot get it to TV as it is stuck on Sky! It's a Thomson DSI 4212.
Help!
FRANTIC FRANC
There probably isn't a code that will work the volume etc (Samsung's are a nightmare!). If you switch off the Scart control in the digibox settings (services, system setup, picture settings) you will be able to jump back and forth to the TV 's tuner using your TV remote (av button/source/etc).
Other than that pull out the scart lead to the digibox :(
Cheers, Franc
