Box Stuck in Standby, Help????
B Caine
Can anybody help me? My digi box would not change channels so I turned it off at the mains, when I put it back on it will not go out of standby, the led flashes but it won`t budge, I`s an old set a Panasonic ???20 and never played up before. Can anybody help me please? Many thanks for any replies.
Starburst
It could literally be anything:(
However had a quick look through the Satcure Website and found this paragraph...
"Panasonic D814 in power supply. If Digibox is "stuck in standby" or LEDs are flickering, disconnect one end of D814. If Digibox now works, the protection diode is faulty. "
So the problem could be related to the PSU, but I am no expert.
GGTVBD
Usually the processor faulty, I believe. Very expensive to repair. Not worth it in my opinion.
I'm sure you'll be able to find a decent later model Panny on here for £50 or so.
Hope this helps.
Podcast: REL T/9x Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
