Box Dimensions of 42WH18B
Discussion in 'General TV Discussions Forum' started by MickyBoy, Dec 2, 2001.
  1. MickyBoy
    MickyBoy
    Nov 15, 2001
    110
    londinium
    +4
    Can anyone who has one of these beauties give me an approximation of the box dimensions (the cardboard thing it was delivered in, not the TV box). Anything too big could mean I can't get the bugger into the house and this would be A Bad Thing ;-)
    M
  2. gedclink
    gedclink
    If it's the same packaging as the 50" wh18b then the whole size is about 6 inches taller as it sits on a foam base and almost exactly the same dimensions as the t.v..It's effectively a big cardboard sleeve that slips over the television from above. Really snug fit so look for any bumps..
    Ged
  3. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
    I'd guess unless you have non standard doors there will not be a problem, unlikely that any domestic appliance will be too big when boxed to fit through a standard door :)
    btw my 46" WH08B would have fitted through my door, but it was unpacked at my doorstep, as it allows them easier access to the integral lifting points of the TV
  4. Realdeal.UK
    Realdeal.UK
    The dimensions of the box are
    1300 hight x550 depth x1140 width
