Box dimensions of 36zp48?
Discussion in 'General TV Discussions Forum' started by Jaspal, Jan 23, 2005.
  1. Jaspal
    Jaspal
    Before I order the Toshiba 36zp48 can some please tell me the dimensions of the box the TV comes in. It needs to be carried it up a flight of narrowish steps. If I do need to unpack it befoe carrying it up th stairs, does the TV have carry handles to make the job easier.
    Jaspal
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    It has moulded carrying slots.These are not intended to be used to carry for a long distance .Might prove difficuly out of the box.Dont know the dimensions but i know its chuffin heavy.
  3. davee b
    davee b
    Jul 19, 2001
    288
    leeds
    +11
    If its bigger than the 32zp48 box then its HUUUUUGE. :rolleyes:
  4. redaction
    redaction
    Nov 18, 2004
    111
    London
  5. Kiwi Col
    Kiwi Col
    Erm, barely fitted into the back of my V70 with less than 10mm clearance floor to roof....but it did go in....the weight is worse than the size!!
