Bought the Panny E30. Think I should have gone Philips.
Messiah
Bought myself the E30 yesterday but as always happens with me wasn't till I set it up that I suddenly thought it would be nice to be able to loan friends disks without having to finalise them. That I now realise is something extremely difficult with the E30 so think I should have gone the Philips route to enable me to loan out DVD+RW disks and then get them back and re-use them.
Anyone else have issues such as this or how do others use theirs? I know I can just give them a finalised DVD-R but that wastes time and (albeit small cost) a disk.
I wonder if the shop will swap it? :blush:
Also, anyone know if there is any possibility of a future firmware upgrade which would enable the E30 to write to DVD-RW disks. Now that would be just gr8 but knowing my luck it will never happen.
Cheers.
malcom
Loaning out discs is a sure way to having them in a state of destruction sooner rather than later. DVD-R media are cheap so why not record to a DVD-R disc and loan that out instead.
The Panny is a first class piece of kit and I would not consider trading one for the +RW format. Each to his own I suppose.....
Messiah
Yeah, know what you mean. I went ahead and swapped for the Philips thinking you could simply record to a DVD+RW and take it straight out and play in a PC DVD ROM drive (or DVD player).
WRONG. Does not work, not on my PC anyway. Bu**er it. Wish I'd kept the Panny now. That'll teach me (again) for being so hasty :mad: Never mind. Could probably do witha s econd one in a few months so will get the Panny (or latest equivalent) then.
malcom
Messiah. Good isdea! get the second machine as soon as you can afford it. You won't regret it. I have just purchased an E30 to go with my E20. Archiving is now a dream come true.....Malcom
wellsi
Malcolm's right; why loan out discs? DVD-R are now 49p each off the web; dvd+r are still aroudn the £3 - 4 mark...
The functionality of the E30 is way above the Philips; be happy!
Messiah
Thanks guys. I'll enjoy the Philips for the time being and order up an E30 very soon. I thought the cheap discs were proving problematic for many people though? Are you saying the 49p discs are working well?
wellsi
I've only used cheapos, and only the Bulqpack discs gave me a bit of trouble; ie I've had 3 failures out of 80 discs so far...
malcom
Messiah. The cheap media can be problematic with some machines. It seem that all Panny's are not quite equal with regard to disc compatibility. Some are lucky and get away with using the 50p stuff others (Like me) are not so lucky). My E20 is quite picky while the E30 is perhaps a little more tolorent.
Even so I think you will find at present that even the dearer DVD-R media like TDK and verbatim are still cheaper than most of the +RW stuff available at the moment.
I have most success with the FWS brand and more recently on the E30 with Traxdata DVD-R. Verbatim at about £2-65 are fine. The Traxdata and FWS are about £1-10.
I haven't tried the very cheap stuff in the E30 yet! Although a review I read said the E30 was tested on 50p discs without problem. Malcom.
Duvel
Just got the E30 today and all I can say is Wow. Just finished archiving a vhs tape in sp mode and the picture on the DVD looks better than what I started with on tape. Using Datasafe classic for DVD-R and so far so good. Finalised DVD-R works like a dream in my Pioneer dv545. I'm a very happy man to finally be able to do away with VHS.:D :D
Messiah
Ah well. I'm stuck with the Philips now so will just make sure I get my monies worth and enjoy it. Don't feel quite so bad as the E30 I took back cost £490 (locally) and have seen them for sub £400 online. I have therefore saved almost £100 which will go towards an E30 soon :D
Then I'll have the best of both worlds.
M
markbuffyfan
i love my e 30 !!!! and would only change it for the hs2 .worth looking at selling the phillips and getting this for say £750 with the cash you were going to get for the phillips.
yippee
Duvel
I would have liked the HS2 also, but at double the price I just couldn't afford it. Just finished recording 2 NTSC SVCD onto a DVD-R, again I'm really happy with the results. I think I love my E30;) :)
michaelab
Well, just to add a bit of balance, I love my Philips 890 and wouldn't swap it for a Panny E30 or HS2 for anything. Only model that tempts me is the Philips DVDR 1000 MkII.
I considered the E30 before getting the 890 and discarded it because:
- much lower compatability in other players with R/W media
- neither Panasonic nor any shop (nor these forums) could confirm or deny whether the E30 supported multiple PAL systems (eg PAL I in the UK, PAL B/G in most of Europe). I needed this and a quick call to Philips confirmed the 890 did support this.
- cheap availability of the 890 from websites that would ship to Portugal (E30 was next to impossible to find on the net from anyone that would ship to Portugal).
- easy remote control region hack on the 890, E30 requires chip mod.
- chasing playback and other time shifting trickery were not important to me.
- I could get a demo record/playback quality of the 890 in several London shops (when I was visiting). Couldn't find anyone with an E30.
- I prefer to buy European, all other things being equal.
- E30 looks like a home electronics kit assembly :D, 890 looks just gorgeous.
Since I've had my 890 it's been great. Nothing to complain about at all.
Michael.
wellsi
Keeping the balanced view however,
RAM is now included in the new DVD-Multi standard for new players next year, and with write once media at 49p each, is re-writeable compatibility that much of an issue?
Panny is indeed specific to PAL I in the UK, or PAL B/G in Europe, and it's lack of multi region is indeed annoying.
You'll not miss the benefit of chasing playback until you've experienced it; Chucking in a RAM and recording when you're not quite ready to start watching a programme, but want to start it half an hour later... It is the very best thing about the Panny and we use it all the time.
Availability is there, but Philips are certainly more on the ball; but that's irrelevent to the machines specs...
Looks are very personal; I think the philips machine is faceless!
Ian's 2 pence...
dts borg
Can the philips 890 be remote hacked for multi region inc RCE Straight from the box?
If so think I will get this and forget the Panny E30.
Thanks dts......;)
michaelab
890 is remote hackable to multi-region but the hack won't let you play RCE titles. You can however set it to a specific region (eg region 1) after which RCE titles will play fine. Of course you then have to switch back to Region 2 or multi-region to watch other (non region 1) films.
There are some other 'tricks' for getting RCE titles to play which don't require re-hacking.
Also, just an FYI: allthough the hack is a remote control hack it can't be done with the remote that comes with the 890. Need to use something that can send specific RC6 codes (like a OneForAll 6, Philips Pronto etc).
There are countless threads on DVDPlusRW.org about the hack and RCE tricks. Do a search.
Michael.
wellsi
So the Philips machines are unstable then...?
(grin)
Machine Head
Hi....I'm new on here so be gentle with me:)
Anyway, I decided to register to get some advice on which DVD recorder to buy. I had already decided to get either the Panny E-30 or the Philips 890 and thought I might get some advice. But having read some of the replies I'm more confused than ever. I'm very tempted by the Panny but would like more compatibility as well as multi region. I was impressed by the fact that recordings made on the Panny play on the old Alba so hopefully they will play on my 3yr old Lecson. If that's the case, I could always hook both up to my tv as the Lecson is multi region and I've never had a problem with it. I'm probably muddying the water's but I really do need some advice. Also, where and for how much for can I buy the discs needed for either recorder and are they available at PC fare's. Thanks in advance for any help.
wellsi
As it's post number 1...
This is a recurring question and a quick search will give you hours of fun reading.
The panny does not seem to do the multi region thing easily, but like you, I have an additional player. Format wise, the dvd + / - r discs are bang on equal in compatibility with other players. DVD+RW is a less known entity, and RAM, at the moment, has no compatibility, but does have much greater functionality over DVD+RW. DVD-r discs are as low as 49p; dvd+r are much more...
The panny has totally replaced my vcr and I utterly love it; for me the chasing play back of recordings is easily the best thing; it might not be so important to you.
Suggest you read through the countless posts in this forum...
Cheers,
Machine Head
Thanks for the quick reply m8. Gonna find out more about the DMR-HS2.......I just don't want to end up a Betamax victim.
wellsi
You won't end up like Betamax, as the actual discs are the same size, most players will ultimately read all formats, and a finalised dvd-r or dvd+r will play on most players, as they turn in to dvd-video discs. The only possible redundancy is if dvd+RW becomes forgotten, or RAM; and as RAM has been around for over 5 years in the PC world, it ain't going nowhere...
Don't get too wrapped up in the formats; go for the specs and what's important to you.
Ian
Machine Head
Good advice. I like the i-link on the Philips but can work round that if I get the Panny. My brother and brother-in-law are after dvd recorders so if we all get the same sharing and swapping discs won't be a problem. Things are starting to get clearer.
michaelab
(grin)
The original DVDR 1000 machine and the subsequent 980 and 985 all suffered a number of 'stability' and other problems, pretty much all of which have been resolved AFAIK. The later 880, 890 and 990 machines haven't had any major problems allthough some people have had occaisonal spurious 'bad disk' errors (I haven't).
I didn't know this when I bought my DVDR but it's nice to see that the Philips machines have user upgradeable firmware and the Philips makes firmware updates available quickly and easily.
As I said earlier in the thread, I'd by an 890 over an E30 any day. It has totally replaced my VCR and it's excellent tuner has much improved my TV picture quality.
Michael.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
Latest News
AVForums Podcast: 22nd September 2021
  • By Phil Hinton
  • Published
Creative introduces Sound Blaster Katana V2 soundbar
  • By Andy Bassett
  • Published
Audeze introduces reference LCD-5 planar magnetic headphones
  • By Andy Bassett
  • Published
Chord Electronics launches Anni desktop amplifier
  • By Andy Bassett
  • Published
Roku announces new Streaming Stick 4K and OS 10.5
  • By Andy Bassett
  • Published
