Bought one of those cheap eBay gimbals for my GH3. Not bad...
Discussion in 'Drone Forum' started by photojunky, Aug 19, 2018.
Tags:
  1. photojunky
    photojunky
    Jun 5, 2016
    161
    pacifica, California
    +68
    Decided to take a chance and spend almost $300 dollars on a cheap Chinese gimbal. Well, after messing around with the PID's, I was able to get it working. It was suppose to be plug & play but needed to be balanced as well. As for the jello effect, I did not balance my props and it was loosely mounted with zip-ties so there is definitely room for improvement. Overall I would say I am happy with this product, especially when you consider the cost.
    Cheap Chinese eBay Gimbal for the GH3 or GH4....
