Bought HS10 today. A couple of questions.
Discussion in 'Projectors, Screens & Video Processors' started by rooster, Feb 6, 2003.
  1. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    What is the latest and greatest gizmo to buy upto £100 that will upgrade my sky and X box picture for display on the projector. i have read about the Pro V , is this still the best on the market or should i be looking at something else?
    Also what size of screws do i need to buy for attaching ceiling mount?
    TIA
  2. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    Rooster, where did you buy it and what did you pay?!
    I'm about to buy and severely tempted by pricejapan...
  3. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    spiderv6 bought it from www.nexnix.co.uk
    Total cost £2149 including dead pixel check and delivery. Pondered about importing from Japan myself but decided iafter reading good things about nexnix to go with them
  4. WebLoader
    WebLoader
    hi rooster
    the screws in to the base of the projector are M5, max depth i think is 8mm from what i remember.
    for xbox, gamester make a hi definition bundle, Game i know sell this for £25 , and it includes svideo and component leads, as well as spdif in a breakout box. so you can plug the sony multi connector in to that, or plug the box directly in to the component feed of the pj.
    for sky, then i run svideo , with the DDE mode in the pj set to progressive. you could use rgb->component conversion again but i have not heard how much better that is.
    the DDE scaler/deinterlacer in the hs10 is really good, i would try using that before you make any decisions!
    cheers
  5. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    webloader when you said "or plug the box directley into pj" do you mean xbox or breakout box. I have installed component , svideo and dvi cables up to projector .
  6. WebLoader
    WebLoader
    i meant that you can use either of the 2 sets of component inputs on the pj. there is a set that you have wired up to (3 x phono type connections), and there is the set that is incorporated in to the sony multi connector - the 10 m cable included with the pj
    the gamester box is basically a fat cable in to the xbox at one end, and then a set of sockets on the breakout box , so you can use either of your pj component connections to this.
  7. Dr.Scanlan
    Dr.Scanlan
    Hi Guyz,
    Had a look on pricejapan site, and HS10 works out about 1545 quid...anyone know if you have to pay import tax etc on items shipped from japan, coz a saving of about 700 quid is quite tempting...so long as it works when it arrives!!! :devil:
