Bought a Panny Sky Box - DOH!!
Discussion in 'Sky Digital TV Forum' started by KopiteLad, Nov 22, 2004.
  1. KopiteLad
    KopiteLad
    I had an old ON Digital box that I used to watch freeview on. But the reception here was terrible. The picture used to crackle and break up. I got annoyed with this so decided to get a Sky box to watch the freeview channels on, and to use the old sky dish that we still have on the side of the house. The larger dish used on the analogue boxes years back
    Couple of questions.
    1 - Can you get BBC1, 2 & 3, ITV 1 & 2, and Ch4 and Ch5 on freeview through Sky? If not, can I buy a card that will provide this?
    2 - Ive hooked the box up to the old dish. Gone into the system menu and checked signal strength and the bars are 3/4 full and moving about, so I pressume the dish is aligned properly. But when I go to the channel list, it says "Searching for listings" and then "No satellie signal is being received"? Do the new digi boxes not work through the old dishes?
    Im just tempted to sell the Sky box, and live with just a normal aeriel TV until I can afford the £33 a month for sky. Freeview apparently doesnt work near me, according to the www.freeview.co.uk website...and the pics ive been receiving are proving this.
    Any help would be sound. :lease:
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    1. Yes but you have to buy a card (£20 from Sky).
    2. The dish is ok but you need a compatible LNB.
  3. KopiteLad
    KopiteLad
    1 - can I order the card from sky? and will it last/work indefinately?
    2 - Im just using the stadard LNB that was connected to the dish initially when the analogue box was put up. I just found it odd that the digi box is receiving signal [acording to the sig test] but not displaying any pics, or listings menu.
    Just reluctant to shell out even more cash if its to no avail...i already feel like an idiot for just pressuming the box would all work fine. :suicide:
  4. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Hello,
    Your problem with the dish is more than likely that the dish is pointing to the old analogue satellite and not the new astra 1.... digital satellite which is about 30 degrees to the left of the old satellite signal. Later on sky always used universal LNBs for the analogue service too so maybe the LNB is OK.
    Sky are introducing a new freeview service it costs about 50 quid for the card but it is only valid for 2 years. The only extra channels it gives you are ITV1 and ITV3 I think.
  5. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
  6. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    As above-It's pointing at the wrong satellite! When you see what's on these extra channels you will wonder why you bothered doing it............
  7. Garrett
    Garrett
    Apr 21, 2001
    38,993
    2
    167
    The best thief you’ll never see.
    +6,166
    Also you may miss some channels that were on freeviw such as ITV2.
    I must say I like my Panny Sky box as it allowes me to seed pictures to other sets with the extrs arial out put. :smashin:
  8. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    hi,
    ITV2 is now available on SKY without having a subscription(from last weekend), so the new freesat cards will be able to pick up all ITV channels now,
    Mel
  9. KopiteLad
    KopiteLad
    So its the old "left a bit, right a bit" for me then? :D
    If its off line, why is the signal test on the sky box showing at 3/4 full? :confused:
  10. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    Because it's seeing the signal from the wrong satellite,does it tell you it is "locked" and if so i bet it's locked on the wrong one...........
  11. KopiteLad
    KopiteLad
    It does indeed say its "Locked". You are correct :) Thanks. Ill get out there later and have a mess with it.
    So its just a touch to the left you say?
  12. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    It's not just as simple as a touch to the left,you really need a digi meter to do the job right(although a cheap promax one can get good results if you know what you are doing) You best bet would be to flash a Sky engineer a £10 for doing it ;) Regards,Dave(Ex Sky engineer!!)
  13. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    It's left(from behind the dish) and slightly lower) Look for other digital dishes to compare to,when i worked for Sky i could get them near on perfect just by eye :p
  14. KopiteLad
    KopiteLad
    Dont see many Sky vans stopping near us that often!!!
    How will I know Im locked onto the right sat? Just by checking sig strength and then trying to get a channel?
  15. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    The digits where it say's locked will change,i can't for the life of me remember what Digital is though...........
  16. KopiteLad
    KopiteLad
    Can anyone check on their boxes what it says? :smashin:
  17. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    The say: Network ID 0002 Transport stream 07D4.
