Bought a new WS 32" except
Discussion in 'General TV Discussions Forum' started by lazy, May 6, 2003.
  1. lazy
    lazy
    Ive just noticed that a line travels across from top to bottom. Its very weak but I didnt pay 600 kniker for that.
    The model is a Sumsung 32ws64v. The retail price is 750 but i got mine for 600 cos it was the last in the stock.
    Ive also noticed that the picture isnt that better to the beko 21 inch i was using before. Any ideas or comments?
    I do have 28 days left beofre i return it according to Dixons..
  2. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Is this a 50hz set or a 100hz one?
    If its a 100 Hz one try turning off all the imaage trickery and seeing if it occurs.
    Also does it happen on the av channels.
    I know this can happen if theres alot of other electronic equipment plugged in and can create 'noise' which will cause a feint barr to travel along the bottom to top of the set. This happen in Uni to the monitors there.
    Spunky
  3. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Ah i think i found the one
    [​IMG] or this ones from dixons the others from another site[​IMG]
    As its a 50Hz set i recommend removing all the other equipment first and making sure theres nothing that can interfere.
    Then plug them back in one by one.
    Let us know if it works
    Spunky
  4. lazy
    lazy
    okay ive connected Sky to the scart scoket and pluggin that in and the thats the only thing ive got installed.
    Do you reccomed I install sky via the RF arial? which i add makes the picture worse!
    btw tis a 50hz telly. It was between this one and a nice 32" LG model.
  5. lazy
    lazy
    btw i see that the letters skynews well just the sky part are slightly blurred as is the active on the top right.
  6. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,308
    41
    Berkshire
    +15
    hi, LAZY plug the scart lead from the sky into the scart connection on the tv which says RGB then on the sky system setup select picture settings and change video output to RGB, this should improve the picture. (remember this is also the best input for your DVD player, hence the need for a scart splitter or keep swapping scart leads:mad: )
  7. lazy
    lazy
    Yikes this has made a massive difference to the picure. Thx Cyrus.
    Tho i do still see a very very feint line trveling up and down the screen. Nothing major but what could it be? I only have sky pluggin into the telly nothing else.
    Thx again.
  8. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,308
    41
    Berkshire
    +15
    try a high quality scart cable and see if that helps
  9. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    The feint line travelling up and down the screen is porbably due to either:
    1. Intereference coming though the socket you t.v. is plugged into.
    2. Theres something close by that is outputing a stong intereferece signal of some sort.
    Try moving the set out of the room its currently in and trying a different room, possibly with some sort of socket filter.
    and yes the best picture you'll get is with the scart on the RGB socket on the tele and with it set to RGB and 16:9 on the sky menu.
    Spunky
