bought a Dreamcast, yesterday.
Discussion in 'Nintendo Forums' started by zcaps57, Jul 8, 2002.
  1. zcaps57
    zcaps57
    Hi, folks. :)
    I've bought a 2nd hand DreamCast to play Shenmue.
    Anyway, a RGB scart cable came with the unit, and this is what causing a problem.
    I've got Playstation2, GameCube, XBOX, N64, and DreamCast, and these guys share an RGB input of my TV via Quattro+ (RGB switching box).
    When I connect the DC to the Quattrto+, there's a green/yellow cast on pictures. (This is very noticible, as if Y/Pb/Pr-component video signal is being input to RGB.)
    The tricky part is that if I connect the DC directly to my TV's RGB input, the green/yellow problem's gone. :confused:
    Can anyone see what the problem might be ??
    BTW, is there a such thing as component video cable for DreamCast ??
    If there's one, I'd love to buy one to use it on my front projector.
    Thanks.
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,982
    4
    Nth Hampshire
    +1,094
    no component for DC but the VGA quality is amazing if you can find a VGA adaptor..:)
    Sorry I can't help with your problem, hope you sort it though..:)
  3. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    well done for buying a DC - still the best console with the best arcade games available.
  4. allyh82
    allyh82
    Completely agree TVDUDE, wouldn't part with mine.
  5. spikeyboyo
    spikeyboyo
    Intesting as Carphone ware house are giving them away with new contracts on Vodafone.
    Spike
  6. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Had exactly the same problem playing my DC through the Quattro+. In fact, occasionally the screen would go almost completely green and be unplayable. It was fine when connected directly to the TV though. In the end I bought an S-Video lead for the DC.
  7. zcaps57
    zcaps57
    Thanks for the inputs, folks. :)
    That explained everything. :)
    I'll get a S-Video cable.
    Thanks.
    Oh, good!! VGA Adaptor.
    My front projector accepts VGA(RGBVH) as well. I'll order one from Lan-Kwei.
    :D :)
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Our Dreamcast (wifes really) is routed RGB through the DVD player to Scart 1
  9. Family Guy
    Family Guy
    I got my Dreamcast out of retirement about 4 months and it packed up 2 weeks ago.:(
    I'm top of the list in Gamestation in Sutton when a second hand one comes in. I brought Virtua Tennis 2 and it wasn't a patch on the original.
  10. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    RE: DC VGA cable
    I have one and please bear in mind that only certain games can be displayed in VGA (60hz). But PSO does look fantastic :)
    Dave
