Bought a AMP + Speakers wot else do I need to buy ??
Discussion in 'Home Cinema Speakers' started by jamieuk23, Oct 29, 2004.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    Hi there >>> I have just recently Bought a Amplifier off ebay + I have just orderd the Canton movie CD 1 speaker package with subwoofer.
    My ? is >> wot else will I need to buy to hook up my speakers + subwoofer to my amplifier so I can sit back and relax and watch some surround sound movies.
    I take it I will need to buy some kind of wires or adapters to get everything fully set up and working >?
    if you could let me no wot else I would need to buy that would be cool.
    thanks jamie
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    as all ways thanks for your help mate !!.
    do you think a rookie with no experience will be able to set this all up ??
    or shoudl I be searching for guides now ?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    never thought of checking my AMP manual >> will have a good luck over it now.
    just purchased those wires + adapter you linked me 2 >> cheer mate !!
    you are a credit to this forum !
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    No worries mate hope you ordered the correct lengths tho........
  7. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    nightmare !! they will be only going in a small frotn room >> do you think they will be ok >??
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dunno mate how much did you order have you measured ??????? have you looked at the placement as advised by dolby?
  9. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    no mate I just clicked on those links you game me and added them to my cart and bought them.
    didnt give me a option I dont think of adding length.
    is there need to panic ??
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    er yeah speaker cable is per metre........sub lead was an example at 5m 1m is normally not enough 3m is ok if sub is near amp 5m is general rule of thumb 10m if its...5.1-10m from amp...............
    Priced per meter
    In Stock Price: £0.70 inc VAT
    Did you really think you needed 70p of speaker cable for 5 Speakers?????
  11. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    30m+ ish but a ball of string and an idea where they are going will help........
  13. cmorrison
    cmorrison
    Do you think that these cables will do it justice hornydragon or is it better to spend some of the cash you saved on better and pricier cables???
    that website's prices are well cheap compare to what ive been charged in the past, have you used them yourself mate?? :smashin:
