Bought 2 used amps not working
Discussion in 'AV Receivers & Amplifiers' started by curtisgc, Apr 10, 2016.
  1. curtisgc
    curtisgc
    Apr 10, 2016
    morongo valley,c ca
    I bought 2 different amps from 2 different guys and I cant get either one to work.
    First is a Pioneer vsx-52tx. The only way I can produce sound is to run the manual mcacc and and it will lower the db to 0 and then I hear sound. Otherwise the db is always stuck at 80db and I don't have a mic to calibrate it automatically. My question is, do I need to calibrate the mcacc with a mic in order for the amp to produce sound?
    Second I purchased an onkyo Tx-nr901 and it appears fine in the display but no sound. Do I need to calibrate or what? I did factory resets on both units also.
    Thanks in advance,
    Curt
