Bottom Mounted Speakers for PDP436FDE
Discussion in 'Home Cinema Buying & Building' started by sjuggins, Mar 12, 2006.
  1. sjuggins
    sjuggins
    Guys,
    Anybody know where I can get the bottom mounted speakers instead of the side mounting ones? The space I have between the TV and mantel piece is the perfect size for these speakers, the side mounting ones though are too long if you lay them end to end under the TV.
    Anybody know what the dimensions of the bottom speaker?
    I'd be interested in a swap if anyones got some.
    :thumbsup:
  2. Reaperman
    Reaperman
    Jan 8, 2005
    636
    Stroud, GLOS
    +28
  3. sjuggins
    sjuggins
    Spot on, thanks :thumbsup:
